4" lift kit w/ 3.21 gears...
Jersey1500
New Jersey
2014 CC Sport
Hi All,
I'm one of the unfortunate few who learned after I purchased my 1500, that my truck came with 3.21 gears!
I am now in the market for a 4" lift and a nice set of 35's and would like to hear from anyone who installed a 4" lift w/ 35's and KEPT the 3.21 gears:
  1. How the truck performed after lifting and adding larger tires?
  2. What specifically will I notice... sluggish off the line performance? Any degradation in shifting?
I have the 8sp tranny, btw...
Thanks!
ItsMeKO3
Canton NY
I don't have a 4" lift, but I have a 2" level with 315/70/17 (34.4"). Mines a 14 with the 8 speed and 3.21's. Even with the larger tires, it still has plenty of power in my opinion. I lost a between 2-3 mpg depending on how I drive, but you've got to pay to play right? So I wasn't real concerned about the mpg loss. I used the Hypertech Speedometer Calibrator to recalibrate the speedometer for the larger tires. I haven't noticed any change in shifting either. I think the 8 speed really helps negate the power loss going to bigger tires with the 3.21's. Is it ideal? Nope, but it's definitely doable. Hope this helps.
Revo
Canada
5.7L
Running 35s with a level on 3.21s. Little bit sluggish sounding unless you really step on it. I might be wrong, but adding a lift shouldn't have too big of an impact on your power.
jlb
MT
CTD
The 8-spd should help you offset the 35s. I am pretty sure there are quite a few guys on here running 35s with 3.55 on the 545rfe/65rfe trans which based on gear ratios should be about the same.
mjd91
San Marcos, TX
I have about 4" of lift and 3.21's.
I'm running 33's though on wide wheels.
Only ****** part is the downshifting on hills while on cruise control.
Manually limiting the trans to 7th gear eliminates a lot of that.
brandonbomer
Idk about a 4 inch but I have 7.5 inches of lift and lean back about a inch and have a 6 speed. Even on the stock wheels you can tell the difference
bridge
I know this an old thread, but I have 35x12.5 with a 4.5 inch lift with 3.21 gears. Put the tires on 2 weeks ago. I didn't notice any difference in performance, just a loss in mpg.
xrsman
Ontario
3.0 Ecodiesel
Any other mods? I noticed a hit with my 3.92s so I don't know how you haven't noticed it with your 3.21s...
Fryekenn
