4th gen electronics aux panel kit?
jabartram
Corpus Christi, Texas
2020 Power Wagon
Has anyone had issues after installing the kit? i have installed mine and now none of the buttons work, not even the 3 original buttons? do i need to turn on the aux buttons with alpha or did i possibly get a bad switch panel?
crazykid1994
If it’s plugged in and you’ve got power on the harness to turn on and off your traction control than maybe you have an issue. Otherwise double check your connections
SRich2015
USA
Yes, If you have the plugs connected good the they should work!! AlfaOBD just puts them on the Evic and radio. You could have gotten a bad panel.
joelmic
stl mo
2017 Ram 1500 Express Quad Cab 3.6L 4x4 20x9 Wheels
I hope your issue is an easy fix cuz they advertise 'plug&play'
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
Mine went in, zero issues. Stupid question, but, did you remember to put the fuses in?
jabartram
jabartram
2020 Power Wagon
Fuses shouldn't have anything to do with the trac, park and tow buttons.
I took my console apart again, unplugged the adapter harness and plugged the factory harness directly to the switch panel and it still doesn't work.
Im going to plug my factory one back in to make sure it works.
I waited a month for this kit, and im thoroughly disappointed so far.
Sent from my SM-G975U using Tapatalk
TXTONKA
Mine went prefect.. Plug and Play for me.. My new panel was actually sent with with the front parking sensors switch so I went ahead and add that function to my truck..
jabartram
jabartram
2020 Power Wagon
What year is your truck?
jabartram
jabartram
2020 Power Wagon
The switch panel is either bad or is not compatible with my 13 Lonestar. I plugged my factory switch panel into thw adapter harness and all of the original buttons worked normally, plugged the new switch panel in and nothing works, so i reinstalled my factory panel, a waiste of 275.00.
crazykid1994
Did you message them to discuss it? Might be able to figure something out. I wouldn’t chuck it out yet
TXTONKA
Mine is a 2017 2500. Though I had the same switch panel in my 2013 3500 with no issues too.
TXTONKA
I would email them, it took a couple day but they were responsive. I'm sure they will probably swap out any component that is not working properly. Other than slower shipping, I have no complaints about their product or service.
SRich2015
USA
Yes, he is very good to deal with. Mine work perfectly. I read on another forum where a guy got a bad switch panel and he sent out another. With things that are going on right now it may take longer!!
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
As Srich said. I had a issue,( turns out it was shorted wiring under dash), talked with them and was sent a complete new setup under warranty.
Because I am who I am I sent him 100 after finding out it was a truck connector and nothing to do with them
farmallboy
Croton
6.4 hemi
Any chance of them building for 5th gen ?
jabartram
jabartram
2020 Power Wagon
I havent heard back from him since my reply yesterday morning. he may be busy, i know, just waiting.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
I am not sure but I believe the switch panel for a 13 truck is different than the 14-18 trucks. @Ricks Ram may know (At least for the heated seat panel without aux)
M² Mods.
