John Hargadon
- Sep 10, 2018
- 3
- 0
- Location
- Denver Colorado
- 2014
- 6.7 Cummings
Bought my 2014 3500 tradesman Duelly new ! Trading in a perfectly good! 07 2500 bighorn single axle , Last of the Cummins 5.9!! Well !! First problem burned the ****** nextgen tires off the front in like 5 to 7000 miles took it to the dealer and asked to get the alignment checked told it was perfect and was charged for and alignment !! At 52,000 miles the ignition key fob module went out ,could not even put the windows up!! Only 650.00 usd then the headlight module went a mear 265.00 usd!! Then the transmission speed sensor fails !! Fortunately this was covered under warranty !! Then the crappy plastic Y pipe starts leaking !! Had to replace one of the batteries ! Surprise!! EGR CLEANING!! 900.00 USD!! Then the water pump seized up snapping the serpentine belt taking out the fan clutch!! Again fortunately under warranty!! And now the ******* turbo needs to be replaced!! Dealer wants 4000.00 usd can get a exact replacement for 2600.00 usd not installed !! WHAT A ************* TRUCK! 88,000 MILES !! WILL NEVER BUY ANOTHER NEW DODGE TRUCK!!
to Ramforum. Hope your luck changes for the better!
