4th Gen Ram 3"/5" drop
BlueHemi
BlueHemi
Fort Worth, TX
Anyone had an issue with your emergency brake cable hanging loose after doing a drop? Fix?
Quicksilver337
South FL
2016 Ram R/T
remember your rear end shifted forward therefor making the ebrake cable loose, got to get the spohn upper and lower control arms. I have to get the arms as well...
This is UNBROKEN's truck on the Sphon website :waytogo:
BlueHemi
BlueHemi
Fort Worth, TX
Ahhh, gotcha! That will have to be my next purchase then for sure. How much does a set up like that run??
Quicksilver337
South FL
2016 Ram R/T
WhiteExpress
Midland, TX
*cough cough* look at an adjustable trac bar while you're spending the money.
UNBROKEN
2012 Ram R/T
It's still off a hair even with the bracket. I'm **** about symmetry....that last 3/16" or so was worth the cost of the adjustable bar.
BlueHemi
BlueHemi
Fort Worth, TX
how much? don't see it on their site
If you buy any of their drop kits it will come with the kit. If you order a kit and its not in there or if you ordered one in the past, you can email them your receipt and they will send you one. Mine was off a little and we had to fab it to make it work.
Quicksilver337
South FL
2016 Ram R/T
I was just curious as to how much they were selling them for. I have the Spohn adjustable Panhard Bar, very happy with the results.
4.7 v8
So you guys with this 3"/5" drop.....what are your measurements now form ground to center of wheel arch?
Stock:
36" front / 38 1/4" rear
(on my stock '09 quad cab)
If you go 3"/5" it should come down to 33" front / 33 1/4" rear (in theory anyways)....
I'm also running stock size tires as well and will be for a lil while until I can buy some 22s
98sinisterCOBRA
Houston
Ram Express RCSB
I have a 3.5/5.5 when I measured from the bellltech 2/4 it used to be.
Cut (with a wheel)
.5 coil in the front and 1.5 coil in the back...looks great, bottoms out sometimes.
the check it out check my instagram "slobraFTW" I have a lot of pics of it.
