How many of you engage your 4wd just to keep it exercised? Being I live in Georgia and thecroads are always clear, I was wondering if I should engage the 4wd monthly or so just to keep it in good working order......or doesnt it matter?
I engage the 4 WD auto in heavy rain just to keep all parts lubed. No idea if this is needed or not.
I have to wonder, with the 44-44 "Auto".....
If there is no slippage, and it doesn't actually engage, is anything happening in there or is it just like you had left it in 2wd?
If you guys have the bw 44-44 , engaging 4wd does absolutely nothing for you, it's a wet cluctch... so, unless you're USING it, it's not even moving / mounting the plates. The only real way to " keep it moving " is to ensure you're putting it in 4LO every once in a while, this is gear modification and is chain driven, while it won't assist with your 4wd system, it will ensure that should you ever want to use a lower gear in the future, you'll have it, it's about as close as you can get to " keeping things lubed " without actually using 4WD , I.E , spinning your rear tires for your fronts to engage, it will keep it all nice and lubed. The best way to keep things working, is to actually use it. Just clicking the button does nothing, sorry![]()
