4wd lowering?
jeffawats
thompsontown pa
If I lower the rear of my 18 4wd do I need to use airbags if towing or loading in the bed
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Shoot you need air bags in a none lowered truck.!
IMO yes you need air bags if you own a Ram 1500 and want to use it ad a truck.
bryce88
Utah
So when you guys say airbags, are you referring to the airlift 1000 type? Or something else?
22hemi13
Tucson AZ
2014 2500 4x4
Depends on what your towing or hauling. I had a 13 that had a 2/4 drop. It would hit bump stops with a good load on it. Not sure on weight exactly it was bricks like 20 of them. But if your gonna tow/haul frequently rear helper bags would be a good investment.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I spent the money for Timbergrove air bags, very nice bags.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
You must have some heavy toys.....my truck with NO air bags handles my 6500 lb camper and my 3500 lb boat just fine. No problems, no excessive sag......
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Lol in a 1500? Shoot set on the tail gate and it saged, I put 12 small bags of rock in it from homedepot and it dropped 3" if not more.
grizzstang
Calgary, Alberta Canada
Really? Mine sagged to the bump stops with my 5500 lb travel trailer and I changed the rear coils out right after the first tow as a result.
TRCM
USN, Retired
Newport News, VA
I do use a WDH with the camper....with the boat, the rear does drop some, but it still sits higher than the front when driving just like every 1/2 ton tuck I have owned.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I do as well and lower the bags down to around 10psi or alittle more.
Hauling stuff in the bed is were mine sagged bad.
TRCM
USN, Retired
Newport News, VA
Gotcha...noting in the bed usually, but I have had 5 or 6 50 lb bags of gravel, still didn't drop bad.
Heck, I also hauled a d30 & a D35 axle in the bed (complete cherokee axles), no issues then either. But that weight wasn't all at the back............
jeffawats
jeffawats
thompsontown pa
towing my 8x8 aluminum atv trailer with 2 or 3 full size cruisers.After lifting all the trucks i ever had lowering this really appeals to me....was thinking the GF 2/3 or just lowering the rear 2
