4Wheel Drive Selector Stuck
darrenj
Langford
5.7 L
The push button selector on my 2014 Sport 1500 $ Wd is stuck in 2 wheel drive. When you try to press the 4 wheel option the 2 WD button stays in opposed to popping out as it should. Any suggestions? Do I need to replace that whole switch assembly os is there something I can try first?
Thanks
Dean2
Near Edmonton
Sounds like something is bound up or gummed. You might try spraying some Silicone Lube in the gaps around the buttons to see if it is just gummed up. Might have to take it out to get at it good. No idea if that switch can be taken apart, but if it was mine, I would give it a try.
D
darrenj
Langford
5.7 L
THanks. I will give that a try.
