black14sport
- Apr 26, 2015
- 98
- 49
- 2014
- 5.7 Hemi
IMHO, the transfer case was likely programmed a certain way for a reason. Frankly, I like the Auto feature. But I do not like that the clutch won't fully lock when that mode is selected. I'd bet that the Lock mode is programmed from Ram this way because either the clutch itself, or the rest of the transfer case can't handle the torque if the clutch wasn't there. Especially when even experienced 4x4 drivers accidentally leave the t-case locked up when making tight turns.
I honestly think it was just easier for them and more cost efficient to make all the 4wd modes act the same as auto simply because they most likely assumed that if you spent 40-60k on a truck (considering it's only in the higher trim packages) you weren't going to plow snow or use the 4wd enough to know that it doesn't truly lock. I really think it's as simple as that, whether or not it can or cannot handle the wiring mod of a continuous lock, well that also is going to depend on how hard you run it. Obviously driving to work on a snowy day compared to dragging a tree in 4 low or even pulling someone else out of a ditch are 3 examples of tremendous difference in torque output.
It may be (re programming/wiring) a perfect solution for some/most cases, but just as bad if not worse for others. Kind of like the original problem itself. I guess none of us will truly know until someone tries it to be certain one way or the other.
Sent from my SM-G900V using Tapatalk
