4x4
zspace 92
magnum 318
hi
is the full time 4x4 light supposed to light up when in 4 lo i just bought the truck the light doesn't works but the 4x4 hi and low works fine i pulled the cluster put another bulb in (brand new ) still doesn't work
the part time 4x4 light works any ideas ?
xj-JEEPER
Reno, NV
dont currently own one
none
yes it is my jeep is the same way. correct me if im wrong
Mopar1973Man
New Meadows, Idaho
1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Cad axles?
If it is then the vacuum unit is not locking the hubs...
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Or the CAD sensor is out. That does happen.
Also how did you test to check that 4wd is working?
Z
zspace 92
magnum 318
i think it works i got stuck in a snowbank 1 front wheel was spinning an both back wheels but what do you mean by cad axles how can i know if it is
Mopar1973Man
New Meadows, Idaho
Here you go... I know its for a Cummins engine but the rest is the same.
Mopar1973Man's Dodge Cummins Articles - Central Axle Disconnect (CAD) System Troubleshooting
Z
zspace 92
magnum 318
so how do i know if i have cad axles ?
the front axle is supposed to lock ?
Okiespaniel
Work, Shop, Computer
magnum, 5.9
If you have a 2nd gen Dodge, and if it is original you have a CAD system.
If your 4wd is engaging but your light isn't coming on it could either be a wiring issue or your switch on the axle assembly is bad.
Okiespaniel
magnum, 5.9
Here's a couple pics of the CAD system...sometimes the indicator switch gets dirty and won't function. Your actuator also may not be engaging fully and tripping the switch if it's plugged with mud or dust. Or the wiring could have failed.
BTW all this is found on the passenger side of your axle right by the axle vent hose.
Mopar1973Man
New Meadows, Idaho
Because you'll have a CAD (Center Axle Disconnect) Unit on the passenger side of the axle with vacuum line like this one...
As you can see if the unit doesn't move because of vacuum problems then the 4WD switch won't come on... It requires the fork to slide over to touch the switch.
Z
zspace 92
magnum 318
well thanks i will look this weekend
