Raisinbrain
2015 1500 Big Horn crew cab, 5.7 gas, 8HP70 4x4, 99,800 miles.
About 10k miles ago I had both differentials, transfer case, transmission fluid, and pan changed (New OEM pan, and recommended fluids for all).
I began noticing a whirring sound that was a little harsher on occasion. This sound would only show up when the truck was fully warmed up, in gear, and after driving.
The sound was most noticeable at low speeds, e.g. 0-5 MPH, and would go away if shifted into Neutral or Park.
The transmission fluid level was checked at (Aamco) and they said the transmission was not making a sound that wasn't typical.
There are no signs of leaks. Engine and Transmission temps are normal
One last note: If I shift to neutral and back into gear, the noise stops until the next time I drive.
Does anyone know what could be going on?
