5100 Vibration
Had bilstein installed on my 2010 trx4 today. I'm getting vibration at speeds up to 70 mph but can't figure what it is, it feels like it's originating from the left side and gets worse when I turn left but goes away when turning right, what could it be?
mpittman
Indiana
2015 Big Horn Crew Cab
Maybe the Bilstein supplied washer was installed in the wrong location? Seems to be a common screwup.
K
I don't think it's that, this feels more like a cupped tire but stops with the slightest turn to the right. Just a really loud annoying humming vibration
Scgirardi
Make sure tires are properly balanced. Could of had a weight come off.
RamCares
n/a
n/a
Hi Knightinraggedarmor,
If you decide to visit your local dealership for further diagnosis I'd be happy to follow up with them for you if needed. Just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
chrisc75
Delran NJ
sounds like a wheel bearing. usually rolling the weight around by turning the wheel a certain direction will move the pressure on the wheel bearing causing it to get worst or quieter. also did u get an aligment when u had them installed?
