545RE Trans Temp Gauge help
Bushwood,Md
Hey guys I'm in the process of installing my glowshift trans temp gauge, I can't find anywhere on the 545RE test ports to install the temp gauge. Before I go and drop the trans pan and tap an hole in it to except the temp gauge, has anyone installed this gauge am I just missing the test port? Do I need some adapters? Any help would be great!
steermaster
CO
5.7L
WHOA WHOA WHOA!!!! let me get you the part number for what you need, its a little blue block that you install in-line with your transmission lines, it has the sender on top the you run a single wire to your gauge..
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
And of course there is the AeroForce Interceptor gauge that reads a bunch of the onboard sensors including Trans temperature and just plugs into the OBII port.
Trenton
my bully dog does the same thing plus all the other options
Redtruck-VA
Virginia
Yep, I believe most any tuner you can Data Log with will read a good many of the vehicle's sensors.
