5th wheel hitch recommendations
Doug Paper
Pittsburgh
cummins 6.7
2019 ram 3500 cummins with 8' bed dually. will be purchasing a 15k-18K 5th wheel soon and just trying to find the pro's and con's of the many i have looked at online. I have the puck system. thanks for you opinions in advance.
HDGoose
L6 Diesel HO
I'm stalking you! :)
HDGoose
L6 Diesel HO
I bought the Mopar M25 (made by Curt) with my truck. We do one long mileage trip a year. And several trips under 400 miles.
If I towed more, I would have gone with the Trailer Saver. I do not believe you can get a smoother ride than the air ride hitches. I would buy one to match the payload of my truck, rather than the trailer weight, so I would not have to purchase another one.
They have not updated their website, but they do have on for the RAM puck system.
http://www.trailersaver.com/product/bd5-gf-air-ride-5th-wheel-hitch-for-gm-and-ford-trucks/
RogerZ
San Diego
Cummins 4.7L I6
I just bought a new Ram Tradesman 3500 truck and it came with the Mopar 30 installed using the puck system. It is actually made by Curt and is their a30 hitch. It can tow 30,000 lb and has a vertical rating/tongue rating of 7,000 lb. What ever you buy do not forget to check the tongue rating. I tried removing it and the pucks where easy to get out. The total weight of it is 183 lb but when removing it is in 2 parts each heavy but not too bad. It is lighter than my previous b&w companion hitch and it also comes out easier. If removing your hitch is something you often do then this one may be for you. Next week I will actually tow my 15,000 lb/ 4000lb tongue weight Grand Design Solitude with it. I will let you know how it tows.
Cliff Daniel
Cummins
Another newbie here looking for 5th wheel hitch info. 2020, 2500, cummins 4x4.
Anyone with experience with the Ram branded hitches?
Jbinramona
Ramona
Cummins 6.7
I have the Curt rated for 20,000lbs. Been using it for 4 years now. No issues. Tows like nothing is back there. We are 29,000lbs down the road.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
andersen ultimate goosneck mount model #3220 4500 lb pin weight 24000 GTWR weighs 30lbs easy to remove.
barr0208
winnipeg manitoba
Andersen ultimate gooseneck mount model #3220 4500 lb pin weight 24000 GTWR weighs 30lbs easy to remove.
KAKA
