6.4 Oil Level After Change
Chris107
Greetings Guys
I apologize for this question but..... Just changed the oil and filter in my 2500 6.4 for the first time. Put in the manual stated 7 quarts with a new filter. But the oil read about 1/2 quart too high on the dip stick? So are you other DIYers finding the same thing, or what?
Thanks
Jimmy07
After you changed the oil, did you run the truck to normal operating temperature, shut it off, wait 5 minutes, then check it as per manual?
BlkZrx
northeast IN
2016 2500 SLT Std. cab
You never get ALL the oil out. Always put at least a half qt less, run a few minutes, check for leaks, let settle, and finish fill with dipstick level..
Sent from my LG-K540 using Tapatalk
crazy jerry
WY
did two oil changes in my 6.4 so far and 7qt puts it near full. maybe your truck wasn't level when you drained it.
busterbrown
Detroit, MI
2017 Ram 2500 Megacab Laramie
Mine took 6.5 qts exactly after I drained the old oil and installed a new filter. There usually is a 1/2 quart that remains in most vehicles.
