PolarisCobra
From this forum, you are right.
From Facebook, not so much, because people use their real name, and general location.
Yup on phone they could track cell stuff if they had the technology. On my PC I run all through a VPN.From this forum, you are right.
I would. A disconnected battery would be fine, but modern vehicles can give you an unwelcome surprise when everything loses its memory. That's why I would discard all three options you mentioned. Disconnecting and leaving in place, or disconnecting and taking inside both result in loss of memory for the vehicle. Leaving it alone gives the electronics 6 weeks to slowly drain the batteries, which might result in memory loss as well as reducing the life of the batteries.I would not worry about leaving it as is for 6 weeks.
Looking for advice on what to do with the batteries from my 2019 3500 Cummins while we're on an extended vacation of more than 6 weeks.
Ideally, I'd connect them to a battery tender as I do with all my other vehicles. However, the 3500 Mega Cab 4WD will not fit into my garage (too tall for the door), nor will it fit in my driveway (16' driveway, 20' truck!), so it needs to be left on the street. The batteries are about 9 months old, so not NEW, but not old, either. I'm thinking I have 3 options:
1. Leave them as they are, and hope they don't discharge so much in 6 weeks as to not be able to start. This is what I've done in the past for up to 4 weeks without any problem. But from what I know of lead-acid batteries, discharging below 50% can be detrimental to their long-term health. No idea how much they will discharge in 6 weeks.
2. Leave them in the truck, but disconnect them. Not sure what programming this will lose beyond the presets for the mirrors, seat and radio, but those can all be easily re-programmed on our return. Although they will discharge somewhat while sitting, without being connected, 6 weeks shouldn't be detrimental to battery health.
3. Disconnect and remove them from the truck, and put them on a tender in the garage. Lowest risk, but seems like a bit of unnecessary work.
