60750 Miles and Exhaust Manifold leak...
thomasspink
Oxford, MI
2019 Classic
So I checked under the hood after the new 'knocking sound" on my truck. The passenger side heat shield from the exhaust manifold is loose enough i can grab and push the rear portion away from and back towards the engine...
Ofcourse the warranty for the powertrain is 60,000m/5 yr and my truck has 60,750!
Any one have any idea if the dealers would still take care of it?
Or am i pretty much going to have to go get a welder now
thomasspink
thomasspink
Oxford, MI
2019 Classic
Yeah thats what IM NOT trying to do lol
just talked to one of them earlier, they said they (depending on the manager...) can do what they call "good will warranty" since im just over the mileage if it is a warranty thing...
so we will see at this point
BuschLatte420
chill water by day, drink beer by night
WNY
2022 classic tradesmen crew cab 6’4 box
5.7L NON E-TORQUE 3.92 gears 4x4
Same mileage my buddies 2016 manifolds needed to be done
shicksjr01
Madisonville Ky 42431
I have had mine done twice. Dealer told me that it's on dealers to do list now every 70-80 thousand miles. My truck has lifetime warranty so all I pay is 100$. Total for one side was 653$
gofishn
Iowa
hemi 5.7L, 345 cu in
Find another dealer. This should be covered under teh Emission waranty. on my 2014 it was 10 yr/100k miles.
have to look it up for my 2022.
EDIT:
Just looked it up.
8 yrs or 80K milels. Your truck is leaking exhaust, directly into teh atmosphere, before it hit s the catalytic convertor. That is a huge no no and warranty shoudl cover it.
Call the Idiot dealer and remind them of this.
Then, wait for teh oh yeah, i forgot about that. it;s covered.
thomasspink
thomasspink
Oxford, MI
2019 Classic
Just looked at the manual. The 8yr/80k for emissions says
“If your vehicle has one of the following parts, this Federal Emission Warranty covers for a period of 8y/80k….
-catalytic converter
-powertrain control module “
The 2y/24k covers the rest including exhaust manifold…
Dinky
Oregon
My 2014 was out of warranty. The dealer got it covered with the California emissions law. 90k was the cut off they told me.
thomasspink
thomasspink
Oxford, MI
2019 Classic
I can see that the rear passenger top bolt is snapped off. Unfortunately inside…
caulk04
I just did my passenger side manifold the other day, it's a shockingly easy job. I lucked out in that mine broke flush to the manifold so it came out without a welder, but even so that wouldn't be bad.
At 74K miles it was already done once before I got it at 30k. Hopefully I won't have to revisit it again, I milled the manifold flat while it was apart.
ram1500rsm
Trabuco Canyon, CA
Ask the dealer maybe they'll do you a good one since you're only 750 miles past the 60k mark.
I bought my truck used from Carmax with 30k miles and the passenger side manifold was leaking literally 2 days after i bought the truck so i used their 30 days warranty to get it fixed. during that process a few studs broke while they were taking them out and somehow the mechanic managed to mess up the head on that side lol, so they paid for a new head as well, no questions asked, and it was Mopar because they show me stickers and parts. 127k miles as of today and not a single issue knocking on wood....
Jeepwalker
WI
2012 Reg Cab, 4x4
Lol. California is good for something at least
Thats where my nuts come from.
Edit: Pecans/cashews, etc...
M2everist
Denver
I have had to have both sides done. I actually pad for a good local independent shop to do the work because both times the Ram dealership wouldnt look at it for weeks…worthless.
GSSS
Minnesota
I just called a local Ram dealer about my 2016 1500 that just started leaking. His response to whether the repair is covered under the emission warranty was "absolutely". I had talked to another closer dealer that has given me excellent service in the past. They told me not covered.
Thanks gofishn :waytogo:
Dusty
Rochester, New York
Depends on what kind of relationship you have established with the dealer. If you only bring it back to them for a warranty problem, or are grumpy or ***** at them, they may not feel so obliged. If you've blasted them on the internet, don't even bother.
Service managers do have some good will power and funding for these types of events.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build Date: 3 June 2018. Now at 87633 miles.
Gregory McKinley
Piedmont, SC
5.7 E-torque
I have a 2019, Just had the right side replaced under warranty. I have the factory extended warranty that I had purchase because of all the electronic toys built into this thing. If it happens again it will cost me a Ben Franklin. It is now out of factory warranty due to the mileage.
Justin33
EDIT:
Just looked it up.
Is this true I have a 15 ram with 37k and am pretty sure I have manifold leaking I can post video if you want.
