665 cubic inch..
Pushing 1000 horsepower for an airboat ..wonder what it would do in a Ram pick up?
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Those pistons look like 5-gallon buckets.....
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Sounds like my buddies engine...but his is 598 cid, and pushes 1100+ hp.....but it does require race gas to feed it's single 1450 cfm carbs' appetite.
He's detuned it some since he drives it on the street now......
OCDTech
Louisiana
Sorry to semi hijack, but here in louisiana we have the biggest airboats, besides the U.S.Navy.;)
OCDTech
Louisiana
Impressive.
Wouldn't it be awesome to just put that 10.9 liter emblem on your huge cowl hood.
wonder why you don't see more ducted fan airboats. Not only would you get more thrust but it would also be quieter. Probably the downfall would be the suction velocity at the inlet.
OCDTech
Louisiana
Probably exactly that. IC or turbine powered? If turbine, cost as well as a DEFINATE Inlet issue! Fuel, maintenance etc
For most it would have to be a normal IC. The upside to a turbine it is could be set up to run on diesel but the maintenance cost especially if your around salt water would be expensive.
OCDTech
Louisiana
Funny you mention, turbine/diesel. I used to fly RC aircraft couple of guys out there(Way above my paygrade) had actual turbine aircraft, ran on diesel/or actually kerosene i believe. Radar at 250mph!
This platform... http://www.bvmjets.com/Pages/kits/bobcat Composite.htm
bmireault1980
