6” lift + 37s
Moose328
South Carolina
If I get a Zone 6” lift with 3” coils in the rear, is this enough to run 37’s, and if so, what size wheel spacers do I need? Or would I need to do 5” rear coils with bilsteins upfront at 2.1 to have room for 37s?
After perusing the forums a bit I’ve seen to have fallen in the rabbit hole.
R.L.K.
Bristol , Tn.
Subscribed for the discussion.
Witch
Hemi 5.7 liter
Go with the 5” rear coils with Bilsteins upfront at 2.1
If you push them out to far they will rub even at that height
BogsRam14
NJ
^^^ that's me I have a Zone 6" lift with 3" rear springs. Front Bils set @ 0.7. Running 37's no rub. 37's height fit fine..... It really just depends on what rim and tire you will be using. If factory rim you will need at least 1.5" spacers.
Solid State
2011 Bighorn
As Bogs stated, you will need spacers if using your factory wheels. Otherwise, no if you get aftermarket wheels with correct offset.
Maligator
Hem 5.7
I'm trying to decide on this route myself
Sent from my SM-G950U using Tapatalk
Lifted2wd
4" CST lift (front) 1.75" rear
37x12.50x20 on factory Big Horn wheels, no rub no spacers
