Gary2
Is it possiblu that listening to the radio with engine shut off for an hour or so would run down the battery to the point I needed a jump to start in a 2 year old Ram. Battery checked out fine at autozone after being jumped about 5 minutes before being check and was told its 100 % charged and did a load test and said it was fine . Connections look like new as does the whole truck. What are your thoughts . Autozone said the radio would do it but just seems odd to me . Wondering if I go to a 850cca AGM battery vs the OE 730 would help for one thing ?
Also make sure the posts on the new batt. are in correct position when its installed otherwise the cables will be on the wrong side.
