8.4 radio bezel
twinsilk
Bay Area, CA
HEMI 5.7
Bought a ra4 to replace the ra2. Also changing the bezel for one with volume control. Where do you unscrew the bezel to remove it?
djarrett
Monterey, TN
Take out the very top rubber piece where the little rectangular cubby is. There will be two torx screws under the rubber, take those out. Then it just snaps off. It will sound like you are breaking the hell out stuff when you snatch it off. The knobs and air vents will come with it. Unplug about 6 wire harnesses and thats it.
JRust
Oregon
EcoDiesel
Is the Ra4 a direct swap or do you need to change some wiring?
57buick
Salem, OR
6.7L diesel
the 8.4" screen won't look right in the bezel because its a different size. You would want to buy the OEM replacement bezel or do the conversion harness to switch to auto HVAC controls so it fits cleanly
