8.4AN Radio swap in 2010
badjuju2010
Has anyone done this yet? Thinking this will be my next mod
Sent from my DROID RAZR using Tapatalk 2
LB3711
Trumbull, CT
3.6L V6
I doubt it very much. A lot of electronics changed in 2013
Chewy
Bettendorf IA
V8
IMO you'd be money ahead getting an aftermarket system. Sure, you won't be able to control everything like we can, but you don't have all the things we're controlling. :)
badjuju2010
badjuju2010
I like the look of the factory 8.4 unit. I have the nav screen now and liked it till I set in a '13
Chewy
Bettendorf IA
V8
No argument there! I too like it. It's funny because I get in my wifes Enclave and her screen looks downright tiny compared to mine.
kenwitter
Cananda
It is huge. That's why I found it so disappointing that it only comes with a cd/mp3 player. I should be able to watch dvds on a screen this size.
Sent from my SGH-I337M using Tapatalk 4
badjuju2010
badjuju2010
The sport I was in played DVD's.. it had a place to insert the DVD in the center console
kenwitter
Cananda
I have that. But it only plays audio and mp3 cds. My 2010 had the rear VES and dvds would play on the head unit as well. But I don't see anything in my 2013 manual about dvds. I only tried once and it didn't work.
UNBROKEN
2012 Ram R/T
For the money and hassle I'd look at the Alpine Z928HD.
It's almost as big and with a couple of modules will retain the steering wheel controls and everything else and be way easier to get up and running that the OEM unit...probably costs less too.
badjuju2010
badjuju2010
Thanks
WhiteSport
I don't think it'd even be possible. You could find a wrecked 13 and do an entire swap of everything, and I mean everything. The harness is way different, HVAC controls are different... The truck might not look too different from the outside, but they changed a lot more than you think.
badjuju2010
badjuju2010
I may end up trading in on a 2014 sport with air ride suspension
jeepguy_1980
5.7L
I could make a harness that would physically connect the radio to your truck. But it's very unlikely that it would work. It would probably see your VIN and decide not to work. If it got past your VIN, it would probably see your BCM and decide to stop working.
But if you spend the money on a radio, I'll try to help you out.
BlownGP
Houston/Baton Rouge
I dont why you would want it anyways with all the problems people are having with them.
