8 speed ZF tranny fluid/filter change
johnny bullington
piedmont south carolina
I recently just changed my 2015 ram hemi 1500 express transmission fluid and filter. I was able to get 5 1/2 quarts back in it. I’m just nervous that I didn’t get enough fluid into this thing. Has anybody had any similar volumes of fluid put back in their’s? Also what is proper operating temp for tranny?
QwikKota
5.7L
I assume you did a pain replacement? The 8 speed likes to run hot around 180.
Sent from my SM-G900V using Tapatalk
joshuaeb09
Medina County, TX
@Wild one Has posted instructions around here somewhere that came with his replacement 8 speed. You have to get the tranny perfectly level and then follow an overly complicated German designed fill/level procedure to get it back to full.
Hi Johnny,if you jacked it up till the pan rail was level you're good to go.You're about right on the amount,my PPE pan took about 7.5 quarts to fill,and it's a couple quarts bigger then the stock pan is.If you followed the instructions I gave you yesterday,you got it,lol
Rick
meedom
If you look at Boosted's video, that's about the amount he was able to get back in, although he doesn't mention anything
about the pan leveling that they call for in Wild ones instructions from the manufacturer....
You guys should get a sticky for checking 8 speed fluid and service. WildOne has athread already?
16RamHemi
Western Maine
Hemi 5.7 Sport Crew
Rick
forgive me for the dumb question....but what do you mean by pan rail? can i just check level (f to r and l to r) with a 2 foot level on the pan itself and be good to go (with rear tires off ground for the driving portion)?
joshuaeb09
Medina County, TX
He's referring to the lip around the pan where it mates to the transmission itself. You basically want to ensure that the transmission itself, as measured at the mating surface(largest perfectly flat plane on the transmission), is level.
16RamHemi
Western Maine
Hemi 5.7 Sport Crew
thank you
meedom
Don't know if he actually has a thread or not, I've just seen him mention his new 8hp70 and the instructions he got with
it a few times on the forum now....
tfeni52355
Indian Land, SC
2016 Longhorn
5.7 Hemi, 4x4, Air Suspension
Changed the tranny pan/fluid and transfer case fluid on my ‘16 Longhorn yesterday. 5.7 Hemi, 4x4. All fluids in the truck are Redline now. Did the differentials at Christmas time last year. Transfer case and differentials are easy. Tranny not so much.
Gotta love what the Chrysler engineers did (again) with the crossover pipe. Blocks the drain plug on the trannny pan, blocks a bolt on the side of the pan and makes getting to the fill plug a total PIA. I have a nice burn on my left arm to prove it. These are the things the YouTube videos don’t show you.
Truck had 66K miles on it at this change. Glad I did it now. Lots of gunk and grey metal on the magnets. Fluid was very dark. I don’t drive my truck hard other than an occasional WOT. I don’t tow although we are going to be pulling a small Travel Trailer. Truck shifts much better now.
Just my opinion but ZF is spot on with their service requirements. Chrysler is a bunch of BS with their lifetime fluid recommendation.
So a couple of tips:
1) Wrap the crossover and exhaust pipes by the tranny with soaking wet towels to absorb the heat when having to fill the tranny with the truck running. This will save you from burning your arm.
2) Buy a decent garden sprayer and modify it to pump the fluid in to the trans. Have a helper slowly pump while you are underneath filling and replacing fill bolt etc. You have enough to do under the truck. Ask for help.
3) The fill plug is VERY tight when first cracked. I had to use a pipe on the end of my ratchet to loosen. No reason for it to be so tight.
4) Do not attempt this at 10AM when you are taking the wife to lunch at noon. Leave your self plenty of time. 3bb04d297bc38e70faa6215dd0887558.jpg
PoMansRam
East Aurora NY
Nice work!
The garden sprayer is a wonderful tool. I've used it for ATF and gear oil even. The gear oil moves a bit slow, but it works.
What pan kit did you use? I see them online for as little as $30 shipped. Bolts and everything.
I know this thread is ancient, but in regards to the OP's question. If 5.5qts is what came out of it with the pan drop, it's safe to say 5.5qts going back in is going to be fine.
tfeni52355
Indian Land, SC
2016 Longhorn
Nice work!
ATP B-453 Automatic Transmission Oil Pan/Integrated Filter
Sold by: Amazon.com Services LLC
$109.99
I filled the 1 gal garden sprayer twice and it still has a couple of quarts in it. So about 6 (5 1/2?) quarts. I had a lot drip out of the pan as I was burning myself..... :(
PoMansRam
East Aurora NY
Thanks for the link on that pan kit! It's funny how these pans are listed. The 8hp45 (pentastar ZF8) and the 8hp70 use the exact same part number pan, but the 45's can be found way cheaper. If you search for "hemi 8spd pan kit" or or anything Ram or Jeep, the price goes up 3x. LOL.
Here's an example of a $30 pan kit: https://www.ebay.com/itm/68233701AA...rentrq:1d7ff9211750a9c45a3b8a29ffd8d9d0|iid:2
That is a GREAT idea on wrapping that x-over pipe right under the trans pan with wet rags or a towel! That stupid pipe makes the pan drain plug pretty worthless on most Hemi powered 8spds like you say. Thankfully the pan can be pulled with that pipe in place.
It's a shame FCA couldn't follow how the exhaust is routed from the Pentastar powered Ram 1500s. Nice equal length pipes that run along either side of the trans on those. Clearance galore.
southalum
