82 wont start
markm
oklahoma
I have a 1982 d150 club cab that isn't getting any fuel. It hasn't run in a year and i changed the fuel filter and knocked some varnish out of the old one. It is sitting in a shallow and the rear of the pickup is probably a foot and a half lower then the front. I took the fuel line off at the carb and its not not pumping any gas when you turn the engine over. Should i just bite the bullit and get a new fuel pump or does the way its sitting have anything to do. the pickup will run as long as its being fed.
RonJon '06
Southern Minnesota
There is gas in the tank right? A fuel pump on an '82 is cheap and easy to replace. If you replace the fuel pump and it still won't pull gas then I'd look for a clogged fuel line or a hole in the line somewhere.
crazzywolfie
under the truck
have you tried testing the pump to make sure the blockage is not in the tank? really not too hard to pump gas from a jerry can up to the carb for testing purposes.
