8sp trans
RamonaRt
I wanna see if anyone has come across this problem with their 8sp transmission. I'd say 8 times out of 10 when I'm at a stand still and I floor it it spins and instead of going into second it just redlines until I let go off the throttle. It does it on D or if a manually shift it. I'd appreciate any opinions or guesses on what my problem could be.
Kix
Gator Country
6.7L CTD
Well since I don't do that to mine never have and probably never will.
I probably can't even give you a good guess so I won't.
The +/- buttons on the steering wheel only limit the highest gear the trans with shift into, it doesn't force an upshift.
Sounds like you may have a problem with the trans or too much lead foot.
Reactions: Kix
RamonaRt
RamonaRt
Yea I kno the purpose of the +/- buttons. Even if I put it on 3 and I take off full throttle it doesn't shift into second just redlines when it should shift to the next gear. Other than that the transmission works flawlessly and smooth.
misuracaf10
Yeah it shouldn't do that, it should know it's running out of gear and needs to shift. Maybe get it checked at dealer ?
Numnutz
Upstate New York
Either a bad tune, or a bad transmission. That should never happen.
Mine will shift through the gears as it spins.
huntergreen
Marine Corps Navy Badge
i havent heard of this, and i will sometimes floor the pedal from a stop. whats the point of a hemi if you dont have fun once in awhile.\? hopefully a reflash at the dealer will fix you up.
RamonaRt
RamonaRt
Its stock other than a vararam intake, catch can and a welded on magnaflow. Well it looks like I'm going to have to take a trip to the dealer. Will I need to remove the intake and catch can and put the factory one before I take it in?
RamonaRt
RamonaRt
Great minds think alike lol. Hopefully it's nothing major.
huntergreen
since mopar sells a cai, i dont think you should have an issue. CC shouldnt be an issue either.
RamonaRt
RamonaRt
Thanks for the replies. Merry Christmas to everyone
bassheadhemi
Montreal, Canada
Try to do a reset by disconnecting the battery for a few minutes. When I go my truck it would sometimes. I did reset of the ecu and it never happened again
Sent from my SM-N920W8 using Tapatalk
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
Huge win if this works. Going to the dealer is really unpleasant.
Numnutz
Upstate New York
I leave everything on my truck but the tune.
But now that I am thinking about this.
It did happen to my truck three times and it was before the tuner.
It was a factory recall where they had to re-flash. Everything has been fine since.
