98 5.2 EFI going aspirated
Dan98
Tomorrow I'll be going old school with my 98 5.2 it appears easier and cheaper than a program
Sent from my SM-J260A using Tapatalk
tidefan1967
Summerville, South Carolina
You mean carbureted? I ditched EFI on a Chevy 1500 about 15 years ago and went with an Edlebrock 600, mechanical fuel pump and an MSD ignition system. All I can say is what a PITA it was. If you have an automatic transmission you may have problems since the transmission is computer controlled. My fuel economy also dropped to around 13 MPG. Good luck!
D
Dan98
After about 15 hours I have tore down,replaced lifters intake ignition system and reprogrammed valve body trough a shift kit by transgo. Maybe tonight after work I'll install fuel pump carb and rev limiter.
D
Dan98
I read somewhere I can control lockup and overdrive with a toggle switch by shorting to ground. Have any of you tried this or have any idea on the best place to access the correct wires??
