98 Ram shut off after warms up
19Ram150098
My 98 ram 5.2L starts and runs fine (no missing) after about 10 to 20 minutes it shuts off like someone turned the key, even if i have it revved to 3,000. It wont start back until it cools back down and it'll do the same thing again. only showed 1 code for the cam sensor. changed the cam sensor, and no more C.E.L, but still shuts off. I've changed the fuel pump, I.A.C, ASD relay, rotor cap and button, has newer plugs and wires, new battery. Cant figure it out. anyone have any other suggestions or tips?
Hero6
I would suspect either the Coil or the Crankshaft Position Sensor
SportRam00
Joppa, MD
Magnum 360
Crank sensor would be number #1 on my list to check or replace. Any "NO BUS" codes on the digital odometer?
19Ram150098
19Ram150098
Nothing on the odometer, just ordered a crank sensor hopefully thats the problem.
19Ram150098
19Ram150098
Its fixed!!! The crank sensor was the problem! Thanks for the input guys..
