99 Ram 1500 Brake lights
Partytwin
Hello to all and hope I can have an answer to my issue. I have had my 1500Ram truck for seven years. It is a 1999 with a 5.9. Two days ago my break lights simply stopped working. I consider myself fairly knowledgeable but this stumps me. Bullbs ok, brake switch checks ok, breakers, ok, grounds ok!!! All lights work normal. Any takers??
Regards to all
fla crkr 1 ton
Palm Harbor Fla.
5.9 [360]
Check your abs fuses [interior box and under hood box]. I had a 95 3500 that happened to and I checked everything took to the dealer they changed the abs fuse and fixed it.
