A/C Pro?
EWC88
Southern NJ
Anyone use this? My AC is not blowing out that cold, it's cool but not cold. Not sure if I should give this a try or go to a radiator/AC shop.
WalterG
Idaho Falls, ID
I have a coworker that used this on his Ford. Worked well at the time we charged it, but it overcharged it and apparently there is a pressure sensor in the A/C system on the newer vehicles that will shut the system down.
I used to fill my '00 Durango every spring and never had any issues. I don't know if the Dodge has the same thing or not, but you might want to be careful how much you put in as to not overcharge the system.
if your compressor isn't cycling, then you may not need refrigerant. check your cooling fan(s) make sure they are running and also clean the condenser(in front of the radiator) with a power washer.
Check the refrigerant with a gauge before adding any, too much won't make it blow colder and can damage the compressor.
