A/c problems
Workcomp33
Kansas
I have a 04 2500 5.7 4wd. I have replaced everything that pertains to the a/c. U turn the a/c on some times it works fine and when it doesn’t u crack the front windows a little and it will start blowing cold. It does not have duel climate control but the passenger side vents are 15 degrees warmer then the driver side. Some days when it is working right it will freeze a person out. I need help or any help. Thank you
Wallyb4
Retired EWC(SW/AW) 1983-2003
Virginia Beach
5.7L
Are you able to hear the fan? Can you vary the speed of it. Can you feel the air coming from the vents? Is there a difference in the force of the air from the drivers to the passenger side? Have you tried to change where the air comes from? When you do can you hear the the air flow being redirected?
W
Workcomp33
Kansas
Yes to all Yr questions. Is there a cabin pressure sensor somewhere on 04 dodge
Wallyb4
Virginia Beach
5.7L
It sound to me like you have a blend or mode door stuck some where in your air box. I would have to look for a FSM for your veh to see how they work.
