A question for the AlfaOBD Guru's.....
Brian2081
Weatland Michigan
I have a "16" Outdoorsman SLT, I bought OEM LED tail lights to install. The question is, is it possable to disable the "fault sensor" function using Alfa, or am I going to wind up running new wire from the tail lights to the BCM ?
Thanks in advance.
Noneck
2013 Ram 2500 Laramie. 35's 2 inch level. Raceme. Fully deleted 5 inch FlowPro Exh
Not a guru by any means but I'm pretty sure you just go in and enable LED for parking light and turn signal. If you add led bulbs for reverse you'd enable those as well. I just enabled those for my buddies 2015 SL that he added led bulbs to, not the factory LED assemblies, but can't see why it would be different. The geniuses here may know more though.
lpennock
Phoenix, AZ
5.9L & 6.7L Cummins
There is an option that will disable all DTC for rear lights.
Sent from my SM-T500 using Tapatalk
Brian2081
Brian2081
Weatland Michigan
Thanks Ipennock, looks like I will be going on a hunt for this option. Really want the OEM LEDS installed.
1SloRam
Ms
Do you have the adapters? Going from halogen to OEM LED you need the harness because the plugs aren’t the same. Unless you’re going to go a custom route.
Brian2081
Brian2081
Weatland Michigan
I have in my possession the factory connectors and about 6 inches of the harness to boot. A little snip, strip and solder is in the cards.
