A518/46rh help
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
I picked up a 1994 dodge ram 1500 with the 318 engine. The other day I went to move it and it hadn't been ran in 6 months and it was shaking like a leaf on a tree. Then I shifted it into reverse and slowly back up and overshot the driveway a bit and went onto the grass so I put it in drive and it's now stuck. it won't move forward or nothing any help would be appreciated.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Check your fluid. You might be needing to change that fluid and filter to start with.
codered
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
yeah it needs a full tune up the oil is black as coal
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Fluid, filter and band adjustment. How did it look?
Merc225hp
NA
truck
gas
I don't get it has the tranny stopped working or are you just stuck in the grass/mud?
codered
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
I checked it out and it was fine it just needed a good flush and new fluids. merc225 the tranny stopped working also, nice second gen dodge :) . dodge dude's second gen caught my eye too! and the older D200.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Well, watch it's functioning because these transmissions have a habit of starting to slip worse sometimes after a fluid change, BUT since it wasn't working to begin with, you'll get some more lift out of it. You tightened the bands too, right?
And thanks!
codered
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
thanks, and I didn't tighten it I should go back and do it :)
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Well, it's one of those things where you have to do it when you have the pan down because the low/reverse band adjustment is in the transmission where the kick down band is on the outside. (or it's the other way around, I forget)
codered
codered
in da ghetto, FL
1998 QCSB
magnum 5.9/360
Well, thank you I will go back through it and tighten the bands. I got a buddy to help but he has a 1978 Aspen that needs work so we help each other.
