Adding steering wheel volume buttons?
mondo
Columbia, Pa
2014 2wd express rcsb
What does it take to add the 2 buttons on the back of wheel to control the volume and change stations/songs? I bought the buttons and have the harness, anything else needed? Its the 5.0 radio in a 2014 1500 express.
CuylerTech
NH
2015 Big Horn Mega Cab 4x4
6.7L
You'll need the new back cover that has the cutouts for the switches.
mondo
mondo
Columbia, Pa
I should have looked earlier, i took for granted i felt spots to cut out. Just went out and actually looked.....lol.
TRXHemi
Sugar Land, TX
They sell kits with the new cover, the switches, and the wiring harness. You have to pull the steering wheel of course, but before that you have to remove the airbag. There are a few write-ups on this forum with all of the info you will need!
mondo
mondo
Columbia, Pa
Thanks guys. I have the buttons and harness, just need to buy the correct steering wheel back piece then. Thanks again!
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Gibbs
GA
6.7L Cummins
This was the first upgrade I did on my truck. With less than 500 miles on the clock, I pulled the airbag and wheel. I was only slightly nervous, lol.
IMO the hardest part was releasing the clips that hold the airbag/center section onto the wheel.
And although it was covered in the thread linked above, here is a picture of the steering wheel puller mentioned. It was in stock at my local O'Reillys.
If you get anther brand, just make sure it has the 2 "L" shaped puller legs shown here.
R.L.K.
Bristol , Tn.
Couple suggestions for the OP .
I recommend jacking the front of the truck up a bit to get most of the weight off the front tires ...this makes the wheel much easier to turn to get to all three clips required to remove the airbag .
Using a smart phone camera ( mirror mode ) with the picture viewable on the screen side helped me locate the clips quickly.
Don't forget to disconnect the battery [emoji106]
Have a puller handy as stated above ( may be able to rent one ) I just yanked a couple times , then with one hand applied constant pulling pressure while smacking the backside of the wheel with the other hand . It popped right up.
Don't completely remove the steering wheel retaining nut to prevent the wheel from ending up in your face [emoji16]
It's been a few years for me , I can't remember if marking the original location of everything helped. , But I did and had no issues .
Hope this helps !
