Adjustable upper control arms -
knightjp
Dubai, United Arab Emirates
When changing the tires on my truck, I was told that in the front the is a negative camber of 0.5 inches. The shop said that I need to get adjustable upper control arms in order for this to be corrected.
The lift I have is a BDS/Zone 4 inch kit, which is supposed to use the stock upper and lower control arms.
I've looked online and seen a few upper control arms that state for 2 - 4 inch lift. Would these fit my kit?
DILLIGAF
Canadian Forces
Canada
Core 4x4 , If you have a spindle lift you just need the regular ones as they sit level.
I confirm this directly with them.
knightjp
knightjp
I have a spindle lift and so it should be level, however according to the shop doing the alignment, the computer was showing a negative camber of 0.5. I would have not believed it, if they didn't show it to me.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Go to another shop with an alignment machine and see what the numbers are. I bet they're different
joshhhh
