Off_Road_Teacher
Banned
- Jun 28, 2010
- 3,085
- 3
- 2004
- 5.7
well they are in. still wont idle. no codes either....
Will it at least start an then die or not start at all?
the battery was out yesterday so it ws reset right? i guess i can reload the tune. shouldnt hurt right?Did you do a pcm resett first and reload the tune?
Hmm sounds like your truck just doesn't like the cam so you need to take it out and send it to me![]()
its will start sometimes. other it tries to turn over then i give it gas and it will start. when its started i can keep giving it gas and it will stay on but if i dont if will just drop rpms and stall
Are you guys sure that the timing marks were lined up? The sidewinder should not be doing that on the sc tune.
Did you reset the pcm before you tried again?
noob ? i can rest by just pulling off the negative side of the battery? or is it a fuse in the fuse box? lol sorry never done the reset beforeYou gotta reset the pcm. Reload the tune also to be sure
You said your getting a ck engine light? What does it read?
