AF vs SilverBullet Showdown
AF or Silverbullet
  • AF
    Votes: 22 66.7%
  • Silverbullet
    Votes: 11 33.3%
  • Total voters
    33
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
A spark is an understatement. The wrench bridged a header bolt and the positive bolt on the starter. Nick didn't realize they were touching. More than a minute later, the wrench was glowing red ands several wires looked to be melted.
Take some pics of the wiring around the headers. Or a video
Let's see a pic of the wires nick. If they are melted that could very well be the problem.
truckin151
2013 sport
Well ****, should have said that to start with!!! check the wires, and fuses
Bad Habit
Land O Lakes
Modded 4.7l
fuses for sure, i didnt have a spark or a understatement on my 99 and a big ass fuse was blown one that let my alt charge my batt, after replacing both it was just a 10 dollar fuse...***.....the part i didnt understand was the batt was diconected the whole time and nothing arched at all....
S
Silverbullet08
Persona Non Grata
no wires seem to be melted just looked everywhere that had the wrench by it. also i would most likely throwing codes. which im not....
truckin151
2013 sport
the fact that its not is an issue. are you just looking for a cel or are you actually checking?
truckin151
2013 sport
I have had codes that pop up on the key cycle but not on a tuner
shadow11
Banned
Houston TX
Can't you raise the idle point with the sc? Maybe try that idk just throwing out ideas
truckin151
2013 sport
other than pulling the valve covers, check the fuses and wires again and see where they go to and see if any of them look like they melted together, lso check the starter and see if there are any wires that look burnt or melted or like they have been arching. After that I am out of ideas.
You SHOULD be throwing a code for the missing rear O2s though.
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
man, how did i miss this thread..reading the whole thing now... did you get a hold of Sam? what is the status as of today?
S
Silverbullet08
Persona Non Grata
i am talking with sam. he said to drive it but its doing the same thing. wont hold the idle at all. i really want to get ahold of randtx since we have the same setup
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
I bet it's dumpin hella fuel at idle... what year is your truck again? (08 ok) are you running a programmer? can you datalog a/f's? I agree with sam, you have to drive it around alot (2footin) so the pcm an relearn and fill in the tables...
S
Silverbullet08
Persona Non Grata
I bet it's dumpin hella fuel at idle... what year is your truck again? are you running a programmer? can you datalog a/f's? I agree with sam, you have to drive it around alot (2footin) so the pcm an relearn and fill in the tables...
2005 with sc 91 tune and 180* t stat. dont have a wideband yet...
chefred112
Tracy, CA
2005 QC 2wd
392 Hemi
no powerwire or 180 tstat right? they both tend to add fuel..
Jus10case
