After changing 02 sensor
David W Robinson
After changing my 02 sensor on 2010 ram 1500 5.7 I noticed the lighting bolt lit up and stays on now. Hesitates on take off. Just not running right. Any suggestions. Thank you
indept
South Jersey
Have you checked for any stored codes? If you don't have a code reader you can get them read at pretty much any part store for free.
David W Robinson
David W Robinson
Yes, have code reader.
Its showing so many things that might be wrong that I don't know to start.
GraniteRam2015
If you see my post below I noticed I had to disconnect battery and reconnect in order to reset the computer to get the fuel delivery to be normal after changing my O2. I drove about an hour after that and no more code so it’s something to try before going too far.
David W Robinson
David W Robinson
The code that shows up P113, took the neg cable off and hook it back up, the lighting bolt went off but still get the engine light on with that code.
