aftermarket radio not holding time
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
so I installed this Amazon.com : Kenwood KDC-X497 eXcelon Single DIN In-Dash Car Stereo Receiver with HD Radio : Vehicle Cd Player Receivers : Car Electronics
using this Amazon.com: Axxess XSVI-6522-NAV Non-Amplified Non-OnStar Harness to Retain Accessory Power: Car Electronics
it will hold the stations and settings just the clock will not stay correct. any ideas? the harness is just a color match from one to the other. also seems to have a little less bass then with the stock radio and a PAC loc for some reason. I thought the bass would increase. the mids and highs damn sure did
baum
savage, mn
2015 Laramie
double check that when you the truck is off the yellow (constant 12+) is holding at 12v when the truck is off.
otherwise it may be something wrong with the radio
cableguy_hd
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
yeah its weird. all the stations hold. the clock held overnight till just now but the adjustments get off.. tbl mid bass. IDK.
kwend
Twin Cities
2017 Big Horn
If your presets are sticking, then its something wrong with the radio. The yellow wire in the harness connects to a constant 12v+ power source. This wire provides power at all time to the radio to allow the radio to hold your settings (and clock) when the truck is off. Considering the radio presets are still there, its not a wiring issue which leaves your radio as the culprit.
cableguy_hd
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
Sending it back to amazon. Got the x498 from crutchfield coming tomorow so I'll find out
cableguy_hd
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
and wouldn't you know it held it from last night today after I just got the return label to send it back to amazon. first time since saturday
cableguy_hd
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
new radio doing the same thing. I'm going to change the harness next and see if that fixes it
jcat
Possibility of a bad ground somewhere?
Sent from my SCH-I545 using Tapatalk
