Age old, yay or nay on setup?
Mudder
Arkansas
So I'm hopefully (fingers crossed) picking up my new Ram on Saturday. Never too early to plan for the future. Based on what I've read I think I'm good but just would like to hear it from someone else. Plan is...
2.5" leveling kit
18x9 w/0 offset
305/70R18 tires
Does this sound like it'll work ok?
quietpeen
2021 TRX
Hellcat
If you are getting a 2013 or newer 4x4 change that 2.5 leveling kit to bilsteins set at 2.8
Other than that it looks good
jljbtm
I'm going to try the Billsteins on a 2011 hope it works.
Sent from my SM-N910V using Tapatalk
Mudder
Mudder
Arkansas
I have had the Bilsteins before and know they are nice. Considering I fully admit this truck will be a mall queen I don't really see the need for them this go around.
quietpeen
2021 TRX
Hellcat
Then you should look into replacing your UCA's also
quietpeen
2021 TRX
Hellcat
on 2013 and up they didn't make the UCA as robust and trucks with level spacers are prone to popping the Ball Joints in the UCA's.
so a fix to that is using spacers but replacing the uca with a better aftermarket one like zone or mevotech
firemedic10584
Central Fl
dude definitely do the bils. Even if it's just a mall crawler. You'll retain / even increase your ride quality and be a lot better on your angles for your ball joints.
RubberFrog
Just get the bilsteins and save yourself the headache.
Mudder
Mudder
Arkansas
My last one with bilsteins was a 2011. Good to know. Thanks fellas, back with the Bilsteins I'll go
jljbtm
Do you set the Billsteins before install in other words can you change this setting after its installed without taking them back out?
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Good call. You'll be glad you did!
You set the height before installing them and can NOT adjust the setting without taking them back out.
Adam
jljbtm
So the 2.8 setting is what we need to level the Laramie 1500? Will it need aligning after this?
quietpeen
2021 TRX
Hellcat
Yes you need an alignment after leveling a 1500
Mudder
Mudder
Arkansas
Picked up my new truck yesterday so let the fun begin! I've found some wheels I really like but they are 17x9 with +12 offset. Do you think I can clear those ok without spacers? Would run a 35x12.5 tire.
Mudder
Mudder
Arkansas
Any thoughts on the 17x9 +12 with 35x12.5s? Would really rather tuck the tires that much more than the 18x9 0s, but don't want them to not fit either.
noraa73
