Air Bag opinions needed
chri5k
USA
Diesel
Are you able to set the compressor to run 0 PSI with the Airlift system.
AirLift recommends a minimum of 5 PSI to keep the bags from getting pinched or creased. The app and remote for my system will not let me go lower than 5 PSI.
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
Thanks
Sent from my Pixel 3a XL using Tapatalk
NH RAM
New Hampshire
2019 Tradesman 2500 Snow Chief
I opted for the Airlift 5000 Ultimate because I like having the internal jounce bumper in the event that a bag fails. I've run two sets of Airlift 1000 on my previous 1500 trucks and the service from Airlift was fast. The bags keep my truck level while towing my 5w, which I needed because I used a 2" spacer on the front to allow running a V-plow without dragging the edges in travel mode.
olyelr
Kewadin MI
According to Airlift, the minimum pressure is 5PSI.
According to Airlift, the bags with the internal bumpstop are safe to run at 0psi. And I can confirm, after 4 years of running them at 0psi when empty I have had absolutely no issues. Even jumping the truck through sand dunes.
thkbaron
Minnesota
My only complaint with airlift is that their brackets rust in about five seconds the coding doesn’t stay on very well at all at least up here in the northern climate other than that their customer service is awesome and their bags are great
olyelr
Kewadin MI
Been 4 northern michigan winters for mine. They are not much worse looking than the rest of the undercarriage.
thkbaron
Minnesota
Maybe the dodge brackets are better!! My Silverado ones were bad
RndmGlitch
RndmGlitch
That is true - but he was asking about the compressor. The compressor will not allow you to go below 5psi.
SLOfizz
Bay Area, CA
6.4l Hemi
Never heard of Silver Grove, but the AirLifts with cradles have worked great for a couple of years now with the FWC in the bed (9,450lbs dry). I went with the ones that don't have the internal bumps as I didn't want to limit upward travel. I live out West, so my PW sees some significant off-road use.
Assuming that is a decimal point typo. You mean 945 lbs? Hows the truck carry the FWC BTW? I have a project M on order.
olyelr
Kewadin MI
Or maybe entire dry weight of truck and camper?
