Air dam drama
Whammer1
Illinois
I removed air dam on 2020 Ram 1500 due to a 6 inch lift. Anyone find a plug or way to make warning cancel and cure error.
kurek
Northwest
I'd imagine that can be resolved with JSCAN
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Did you get a MIL just from removing the active air dam? Did your add or remove anything else at all? I removed the AAD on three different 5th gens and none threw a MIL (2020 Laramie, 2020 Limited, and 2021 Limited). Have you tried resetting?
Gohemi
Santa Cruz, Ca
Try leaving the motor on and remove the air dam, should make it to down position at > than 40mph and be transparent.
W
Whammer1
Illinois
It’s the avenger symbol. I also put on Corsa exhaust with delete resonator and kooks headers. I always have the check engine light on but I assumed it was because of the different detection of air pressure. I have had all reset and the check engine light disappears until I aggressively accelerate and then it appears. This avenger symbol popped on shortly after I removed the AAD. I have also did a battery disconnect to try to reset all but to no avail. I appreciate all the responses.
Bj Binette
Canada
Can you put it back on and just leave it if it's not in the way of anything?
mikeru
Super Moderator
Eastern WA
2020 Limited
Did you pull the codes? Never assume with something like this when you can easily verify it by reading the trouble codes.
