Air intake replacement filter
turkeybird56
Central Texas
Yep, I stick with the reason I bought mine "For the looks" Anything I got extra is ok with me. I still like the "Old school looks" LOL
Old School Looks: Had a 67 Impala SS with the old L4 Big Block 396. Had no $$$ in those days, and wanted to get more air into the TrashChester Carb. So we took off the lid of the air cleaner and put back on upside down, so had a 1" gap between lip and edge. Forced more air into carb and "sounded" neat, LMAO.
2012RAM1500RT
NC
Yep, turning the air cleaner lid upside down made a Thermoquad (Mopar) and a Quadrajet (GM) moan to where you could hear them a mile away!
turkeybird56
Central Texas
YUP, sounded so Kool !!!!!!! Them POS Rochester spring loaded junk, LOL. I disconnected the thermal on the choke and used a hand choke to set it where I wanted in, LOL.
David James
Fredericksburg, VA
jagman_xjs
Clarksville IN
2003 2011 2019 2023
5.7 Hemi(s)
The reason I do NOT like K&N is because if you look closely at them. They have pinholes in them therefore letting DIRT come thru. I have one on mine and as soon as I can find something that can hold up to the air being pulled by the supercharger that K&N is GONE.
gto64gto
Tbor City NC
I know I won't be popular saying this but I won't use a K and N air cleaner again. I had a 2009 Charger RT with one and I kept it clean and didn't over oil it but I had to clean my throttle cleaned. I had to do it several times. I think this is because of the oil from the cleaner.
Siff
New Hampshire
That's the way the oil-impregnated filters are designed to work; the oil saturates the material, filling in the pinholes and forcing the air to pass through the oil which is meant to cause any particles up to a certain size to get trapped in the oil.
It's not like a dry filter, where the air passes freely through the pinhole; it's more like a b_o_n_g, where the smoke passing through the water is meant to filter out some of the particulates in the absence of a solid filter.
rvance
Pent 3.6
I had a 69 hemi long block that I got from a machine shop that blueprinted it for the cost of the machine work. I needed an air cleaner and the only ones available were very expensive. Especially in 1969 dollars. I got a 5/16 aluminum plate and cut it to fit over the carbs to hold the factory filter. I had a 7/16 piece of tempered glass made for the top. Talk about looks! I sure wish I had the pictures, but in the last 50 years they seem to have evaporated.
the whole idea for the oil soaked filters, was the old OIL BATH filters,
no one liked the looks of the oil bath filters & many ppl use to mishandle them & spilled oil all over the engine compartment
first mods were similar to this,
then for an Oil Filter, they used toilet paper
You could find the Frantz bypass oil filter at any swap meet for several years, i have not seen one recently
his review of the product, still made a mess
Arturo Rojas
