AlfaOBD help with 2012 Ram led turn hyperblink
OnSale
5th Gen Crew
Philadelphia, Pa
I know that you can turn off the led turn signal hyperblink with AlfaOBD but my question is can you do it with a 2012 Ram and what are the settings that need to be changed???
OnSale
OnSale
5th Gen Crew
Philadelphia, Pa
Nobody knows the answer to this??
1500ram12
5.9L Cummins
I don't believe you can with a 2012 since led's weren't an option until 2013.
2018 Ram 2500 6.4L Hemi Tradesman
'11
6.7L ISB
For the early 4th gen you still have to use resistors for the computer to see correct voltage.
Sent from my SM-N950U using Tapatalk
1500ram12
5.9L Cummins
A different app was posted a couple of days ago that works on 2012 truck's that says it can change led settings. It's called obd jscan.
0cb8c0bbf0956af05996dca66f3ecd1c.png30731044757493387ffaf7976fe38bcc.png1bd826eefe7deb4471a84b9aaa6a49b0.pnge8f0232976bbc0d62ea8af39137084fc.pngbd41cb6174e2441a90678bf0b6c3dcf6.png46463149f67f2a0b2a5882a6836111fe.png14869205d66085c667ed0df41084ce0d.pnga25d37c7072a67b2b581d7533a49daf8.png
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Interesting... Menu layout like better than AlfaOBD but I don't see Ram support officially listed... I wonder how much a full license (locked to a vin) costs?
In app purchases show $0.99 to $169.00 ?4e11eb6867fdce403db51f0e870a61a9.jpg
M² Mods.
1500ram12
5.9L Cummins
M² Mods.
I think it's only $17. But I haven't connected this to my truck to verify. But under the demo version in ram that was what the price was
ajairola
Houston
I seem to remember that depending on the trim level of your Truck, it had tolerance for LEDs(my 2012 Laramie never gave me issues with LED taillights, when others reported needing resistors). Not sure where in Alfaobd you could find the setting.
OTownRam
