AlfaOBD mileage change failure
1500ram12
5.9L Cummins
Can you change mileage on 5th gens now?
I haven't seen anyone say that they were successful yet. A few have been able to change the hour's. But they could just be having the same issues as 4th gen owners
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
PCT
2019 2500 6.4
Northern California
Good to know, cause I was close to buying the cluster from infotainment. Will I run into any warranty issues swapping em?
1500ram12
5.9L Cummins
You shouldn't. I doubt anyone would ever notice. I've never had any ask about the 7" cluster in my tradesman
McIrish
Henderson, NV
Having issues with mileage correction. I have tried with everything up to date with the android version and obd mx + using koad bypass harness with no luck even tried several key combinations and changing alphaobd connect settings. i purchased the windows version and was able to get idle and total hrs changed using the usb obd ex link but mileage still wont correct. i also tried 7in and 3.5. just wont change it will flash the IPC and say complete let sleep but no change/luck. any ideas WOULD BE APPRECIATED. THANKS
2020 Ram 1500 classic
2020 EVIC
Sami932
Dubai
2020 EVIC
Did u find a solution.. im having same issue windows and android both
Heathen-19
Midwest
I have a 2019 and have done the same thing and can’t get it to change. Was able to change tire size for speedo correction, idle hours, drive hours, global windows down, VTA and fog light high beam dropout using android version and MX+
