AlfaOBD need help
Aarron
Tennessee
3.0 ecodiesel
Hey guys sorry, new guy here,
If someone could maybe help me,
I’m trying to program a new fob to my 2016 Ram got the key off amazon part number matched,
But when I try to program it I keep getting a error; (failed conditions not correct or request sequence error)
I have the PIN number and drive the 0000 but can’t seem to make it work?
Anyone else have this issue?
chrisbh17
Is the ignition completely off? Cannot be in run or accessory to do this
Sent from my Nexus 6P using Tapatalk
A
Aarron
Tennessee
3.0 ecodiesel
Yes I have the truck turned off, followed the thread on here the “how to” and no luck
chrisbh17
Which type of fob is it? The push to start one or the one that needs to be inserted into the ignition?
Do you have a link to the one you bought on Amazon?
yomanne
Cedar Falls, IA
This is long after the fact, but I also have run into the exact same problem trying to program a new fob. Was there ever any resolution?
yomanne
Cedar Falls, IA
I now have the answer to my question. Turns out you have to choose "Program Ignition FOBIKs Baseline System" instead of "Program Ignition FOBIKs". Then, it's just a matter of inserting the new key fob in the ignition, leaving it in the OFF position. Although I don't know if it's absolutely necessary someone said to turn on the emergency flashers, so I did. Then, after entering the four digit PIN and pressing START, it immediately programs the new fob.
