warwagon98xj
- Feb 15, 2015
- 113
- 40
- 2014 2500 CCSB
- 5.7 Hemi
Oh ok that makes sense thanks
You should be able too. I did it on my quad headlights. Try your low beam or high beam and confirm it is working then try your turn signal.
I can't for the life of me get anything to change on my premium IPC now.. seen the update and got excited but nothing will work. I've waited over an hour with the truck asleep and even tried unplugging the battery for a bit.. can't change the hours or the mileage.
Sent from my SM-N950W using Tapatalk
A stupid question but did you make sure you updated your app. Also. He did update the app a few days after the original update but how are you trying to program it. Your truck should be completely off with the doors closed.
Yep. Reboots with the previous milage. Won't change.As Lawsuits11 stated make sure that the app actually updated. It took me 2 time's on my kindle for it to actually update. When you program the mileage it will have a selection for either 3.5 or 7" clusters. And after the cluster reboots the mileage will be changed.
When you go to change mileage the way I did it was (skipping some steps, and going off memory)
1- truck to run position
2- connect to instrument cluster
3- choose 7"
4- alphaobd will have you turn the key to off wait a minute and back to run
5- enter mileage
6- cluster will reboot with correct mileage
2018 2500 6.4L Tradesman
I'm running 2.1.7.3 on Android. Maybe the latest patch bugged it?
I had the same issue it took about 24 hours after enabling both of these. Just double check you have BOTH of these enabled then clear the code and let the truck sit over night. I am using diesel LEDs brand switchbacks.Anyone using the Headlight Revolution LED front parking/turn light bulbs? These https://headlightrevolution.com/2009-2018-dodge-ram-reflector-style-front-led-turn-signal-bulb-kit/.
I have parking and turn set to LED in programming. I get parking light out error when parking lights are on and turn signal is activated. Happens both left and right every time turn signals are activated. It's almost light the parking light drops off briefly (although it does not flicker) when turn signal is activated. I have resistors on the turn signal side. Maybe I need to add them on the parking light side?
Giving up for another bit I guess... Maybe it's bugged? When trying to change the mileage on my 7" cluster it reboots approx 4 times and boots back up to the old mileage unchanged. Put a few km on it to see if it would change and still didn't. I've tried doing it with the engine off, on acc, on on, and with two different adapters and two different android devices.
Maybe the latest update bugged it? Not sure..
Just shot the video guys! It's probably going to take me several hours to edit. I'm hoping to get it uploaded tonight. [emoji6]I have received a few people asking how to program Lifetime drive and idle hours. I made a walk through to help people out. I will quote this post with the walkthrough.
@Big daddys house. You should do a video for programming the idle and engine hours if you can sir!
How to program Idle/Drive hours on premium 7” EVIC
Connect to your instrument panel and click the car with the hood open
Click on the drop down menu
Click on program custom features towards the bottom of the list
You will see a second drop down menu. Click on it and you will see your two options for programming your Lifetime idle and Lofetime engine hours
Your Lifetime Engine hours is the TOTAL hours your truck has been on. So you need to add your Drive and idle hours from your old EVIC together.
Example
Idle hours on old EVIC - 350
Drive hours on old EVIC - 605
Your Lifetime engine hours would be 955.
That is what you enter in the Total engine hours box Show in the pic below
Next click the second drop down menu and select Lifetime Idle hours
This is where you just enter your exact Idle hours on your old evic
After this your evic will calculate your Drive hours itself. So you don’t have to do anything else
Disconnect and close AlfaOBD like normal
I can try and send you the apk file from the last update if I saved it
