AlfaOBD
kad
Hudson Valley, NY
5.7L HEMI
Ok just checking I have Apple products so I guess I will have to stick with the genie or just go to the dealer :(
If you really just want to do the DRLs and don't want to play with all the other fun stuff that AlphaODB can do... if you are close to one of us who has it, someone might be willing to do it for you. Where are you located ? (Your location isn't set in your profile)
-K
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
-K
I’m in North Alabama, I’d do it if you’re near me.
This goes for anyone really. I’m up for doing whatever you need out of alpha, to include the recent ability to adjust TPMS pressures, provided you have the RFH PIN.
Ricks Ram
I'm in CA and would be glad to do it.
Chief_6.7
-K
That would be sweet but I’m in a place where no one ever comes to. Hahahaha El Paso Texas.
Ricks Ram
On another topic for those of us who have activated the VTA in our trucks if you unlock it with the key instead of the fob the alarm is still armed. Not really a big deal but worth noting so you dont accidentally set it off like I did. I doubt the trucks equipped with the VTA from the factory act the same way. Might be a setting we are missing.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I'll check mine tomorrow, it came with VTA.
M² Mods.
Cesar592
3.6 pentastar
you know what function this has
Ghost_RAM
Ghost_RAM
VA
It is for vehicle entertainment (assuming overhead dvd) 2nd and/or 3rd row.
Cesar592
3.6 pentastar
I am trying to put the smartbeam mirror but there is something I can not find puddle lamp present to enable Mirrors Interior Rear View and Exterior:
Interior EC Mirror Present
Puddle Lamp Present
Select “yes”
Mirror Turn Signal Present
Select “yes”
Electro-chromatic driver mirror present
Select “yes”
Electro-chromatic passenger mirror present
Select “yes”
Under “program customer features”
EC Mirror Auto Dim
Select “enable” ...I believe this merely turns on/off the auto dim mirror which can also be accomplished through the menu settings or soft key on the 8.4 screen.
Enviado desde mi iPhone utilizando Tapatalk
Jkieffer
Not sure where it is but I thought there is a smart beam present "yes"
I noticed it some where.
Ghost_RAM
Ghost_RAM
VA
Puddle Lamp Present
Select “yes”
Select “yes”
Select “yes”
Select “yes”
EC Mirror Auto Dim
Definitely enable small groups if not individually when doing this. Allow the truck to sit, key out, doors locked and away from the vehicle for at minimum 5 minutes. Some settings will also take much longer to take than others and different year trucks (older) also take more time for some settings.
What you have listed is for the exterior mirrors. The smart beam mirror and puddle lamps are two separate items. Puddle lamp present is located about midway down the list if I remember correctly. It is very easy to skip over.
The smart beam mirror is part of the Auto High Beam.
Auto Highbeam
Select “yes”
Select“yes”
Smart Beam Present (AHBM)
Select “yes"
Auto High Beam Module Location
Select “ECC_AHBM"
Auto High Beam CSM
Select “yes”
All the above of course is dependent on the correct hardware/wiring being installed.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
So I'm back again.
I wanted to change the back splash of my EVIC to say "Limited" when the truck is started. Followed the procedure and nothing changed. Did it a few times and double checked it took and it it did.
I am starting to wonder if this is something that will only work on the 2016+ trucks?
Ricks Ram
So I'm back again.
I don't think it will work on the 2013 and 2014 trucks. I believe it stared to be an option on the trucks in 2015 where when you started it it would show Bighorn Limited or whatever trim level your truck was. My truck is a 2014 and I tried to enable it just for the heck of it and nothing changed in my truck either. That being said I'm not sure if it's because my truck doesn't actually change the image depending on what trim level is programmed into it or since my premium speedometer is out of a 2013/2014 truck and is just not capable of showing it.
Ghost_RAM
Ghost_RAM
VA
The change of the EVIC may be limited to the year model. To verify though, did you change both special packages sections at the top?
Ricks Ram
I'm pretty sure I did both but I'm going to go try again just to make sure. The thing that gets me is my speedometer is out of a 2013 and my truck is a 2014. We have learned that the 2013 speedometers have some limitations as far as a graphics. We have found that the 2013 speedometers for some reason don't show front park assist and I'm assuming it's because it was not an option in 2013. We put a 2013 premium speedometer in STecoD's mom's 2014 and it no longer shows the front park assist on the EVIC. I'm actually going to start keeping my eye out for a 2014 or 15 speedometer a stick that in my truck.
Ghost_RAM
Ghost_RAM
VA
@Ricks Ram Thanks! Yeah, I remember reading to stay away from 13' clusters when I was looking for one. They also had TPMS issues I believe on newer models.
@Arth Did you install your premium EVIC or did it come with your truck.
Ricks Ram
I installed it in my truck. The 2013 speedometers TPMS will work in the 2014 truck but the 2014 speedometer TPMS will not work in the 2013 truck. I switched mine out almost as soon as I bought my truck so trying to find a 2014 premium cluster was almost impossible and I ended up with a 13. I have had no issues with it whatsoever but I notice it does have some differences compared to the newer ones as far as the way messages like key in ignition ect are displayed plus now we know they wont show front park assist. At the time we didn't realize there was any difference in their graphics or anything between the different years because we hadn't had enough time or examples to look at.
chrisbh17
For those who have added memory mirrors (or at least know what they look like), is there any way to tell if a set of mirrors have memory function just by looking at the mirror and/or wiring?
Ive found a set with chrome caps on them, but the exact vehicle they came from isnt known. Hoping the wiring might be a good indication?
Thanks.
-Chris
Ghost_RAM
Ghost_RAM
VA
Thanks.
-Chris
I would ask the seller for detailed pics of the back of the plugs. Sending you a PM
noraa73
