AlfaOBD
Cuong Ly
Philadelphia, PA
Diesel 6.7L
Can someone help me program my keyless entry on my 2011 2500?
When I brought the truck a few months ago. It only came with they single key to the left.
I ordered two OEM keyless fobs
The problem is when I get to the last step “ PROGRAM IGNITION KEYS or KEYS FOBS “. It gets stuck at started please wait.
My procedures. I inserted my original key into the ignition. I turned it to run position.
I connected my android phone>Bluetooth>Alfaobd.
when I get to “PROGRAM IGNITION KEYS or KEYS FOBS”
I turn the truck off, remove the original key.
Insert the new FOB
Turn the ignition to ACC
I enter my 4 digit pin
And I hit start.
and it just hangs there.
chrisbh17
https://northcoastkeyless.com/produ...t-auto-side-steps-fcc-id-gq4-54t-pn-68159657/
Hi !
I just saw that this key is in store but it has already been used, could I still program it ? or it is better to take it new
If its already programmed it needs to be cleared before it can be reprogrammed. Only a dealer or locksmith (with presumably expensive tools) can do that.
Stick with new, even if you have to buy a generic brand (I had good luck with KeylessOption on Amazon)
jlsalani
I have what might be a silly question... just had my CEL go on and then right after that a cluster notification that my left tail light was out. Replaced the tail light and then used Alpha OBD to check the code.. got B1642, tail light short to ground... cleared the code and now there are none left, but the CEL will not go away?... is there something I am doing wrong?, or does it take key cycles after I clear the code before it goes away? I have had other OBD SW that when I cleared the code it turned off right away.
..... and is that normal to have to have a CEL light up with a tail lamp being out?
Jimmy07
There is some other issue going on. Most faults in the BCM don’t request a CEL, and definitely not lamp faults. Check all the other modules for faults, starting with the engine.
jlsalani
ahhh.... think I get it now. I thought that all codes were shown regardless of module. What are the major ones for codes, engine for sure, and body controller... any others?
looks like it was just a coincidence that I got a CEL and tail lamp out at the same time!.. next work break will go check again. Thanks.
Jimmy07
NicksGarage
Ramona, CA
5.7L
I programmed two fobiks to my 2009 Ram 1500 and it says to run these two things but the first one says only if you have ELV/ESCL. How do I know if I have that? I don't have Keyless Go so do I need to run the PEM Replaced? I don't want to damage the WCM.
The two new fobiks start the truck but the RKE functions are messed up. The lock button unlocks the doors and the unlock button flashes the lights. Scan tool says that the lock buttons are set to Unlock and the unlock buttons are set to Liftgate/Lid. I didn't try the panic buttons.
Do I need to run the ELV or ESCL Replaced procedures?
tnctx02
2017 RAM SLT
3.6L Pentastar V6
Insert the new FOB
And I hit start.
Having the same problem but with a 2013 Tradesman. Anyone got any ideas?
John Wauters
What odb interface are you using? Alpha seems to only work with its tested devices.
Sent from my SM-G998U using Tapatalk
NorthStar1
Rosenberg, TX
2020 Ram 1500 Big Horn/Lone Star 4x2 Crew
Hemi 5.7 eTorque
Is there any where one can find what the AlfaOBD updates contain? I updated to Version 2.2.9.0 yesterday but don't see much difference. Thoughts?
mtnrider
Georgia
If you look at the "whats new" section on the app page in the play store it tells you. Not a ton of detail but that's about all you will get.
"Various fixes and updates. Update for RFH PIN read from different vehicles. Update for car configuration options on CUSW vehicles."
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
You sure that wasnt version 2.2.0.0? Mine updated oon 28 April to 2.2.0.0 not 2.2.9.0. Just wondering if different version were sent out....
NorthStar1
Rosenberg, TX
Hemi 5.7 eTorque
The upgrade I did was on a Windows laptop version of AlfaOBD (not the app version).
