AlfaOBD
Jimmy07
will my security bypass cable for my 2018 work on a new body style 2019 plus or are they different? Thanks
If your 2018 bypass cable is for the 2500 in your signature, it will work on the 2019+ 5th gen 1500 (new DT body style) trucks. For it to work on a 2019+ HD Ram, you would need to snap of one of the raised key way ribs on the green canbus connector.
SRich2015
USA
Thanks, I let someone borrow it and he has a 2019 3500. I'll let him know he will need the 2019+ HD cable.
Gus T
So cal
Hey guys I have been looking all though the posts to find the settings I need. I just installed the 52 gal titan tank in my 14 2500. I want to adjust the DTE as well as have the gauge more accurate than just staying on full for 250 miles before it moves. Can anyone point me in the right direction? Thanks so much.
Jimmy07
Try these:
VehConfig 3: Fuel capacity- 194 liters
ECUConfig 4: Fuel capacity- 194 liters
These are the highest values that work, and should get you close enough.
Gus T
So cal
Try these:
Do you think those are the only setting I would have to change? I read about the 1500 guys having to change more settings when the go to the 32 gal tank? Thanks
Jimmy07
Those would be it. Not sure what else someone would change, but those are the only two that have to do with fuel tank size.
Gus T
So cal
Where do I find the ECU config? I don't see that option under the car configuration change.
Jimmy07
That one might not show up depending what year bcm it connects as. You can use the windows version to pull up the 2018 settings list. Otherwise, just try the VehConfig 3 setting.
Caterpillar
France
Rebel 2016
Hello, I still cannot program my fobiks after dozens of tries: the application runs without stopping, say wait
ref. GQ4-54T ebay.com
suggestions
Thanks
chrisbh17
Thank you Jimmy07 but they are new
When I added Enter N Go I ordered one fob from Ebay and another from the Amazon link in the thread. The ebay one was half price, but did not work at all. It probably was brand new, but it just wouldnt program.
The Amazon one worked first try. I later got a good deal on a brand new unused stock fob and that one worked on the first try as well.
My advice would be get the KeylessOption branded fob from Amazon. Thats the only aftermarket one that seems to work.
wickedswede
Avesta
cummins
Why would you want to set it to 90 km anyway that’s only like 55 miles an hour
Hi , thanks for your answers ,, I want to change because here in Sweden the RAM will be
registered as a heavy vehicle ,, and heavy vehicles here are not allowed to have a top speed for more then 90km/h .
as soon as the registration process is done I would remove the speed limit ,, at least that was my idea
Caterpillar
France
Rebel 2016
Thank, i will see amazon
