AlfaOBD
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
My drls are working now.
Not sure if I like my switchbacks on for drls now lol! And I still have the canbus error for my park lights. Haven't messed with that part yet. Hard to figure out what settings need go be changed.
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
Do you have the option enabled in the 8.4 screen (daylight on/off)
I didn't change any settings in my radio. I will look and see if there are more options.
McBroom
Denison Tx
Hemi 6.4L
Any way to get these codes to work with apple phones???
Blue Streak Pearl off-road package
Ghost_RAM
Ghost_RAM
VA
Not at the current time. Only Android and Windows.
McBroom
Denison Tx
Hemi 6.4L
That freakin sucks ass
Ricks Ram
No as of now there is no alphaOBD App that's compatible with iPhones. I'm sure it's probably because Apple won't allow it.
Sent from my SCH-I545 using Tapatalk
randotx
I ordered obdmx and a cheap Lenovo tablet. They’ll be here tomorrow. I have an iPhone too, but this tablet will more than likely stay in the truck now.
Ghost_RAM
Ghost_RAM
VA
My old Note 2 sits in the center console. Unless I know it’s going to be extremely hot as batteries and heat don’t mix.
jcarden10
Raleigh, NC
2014 Big Horn
Read through the thread and didn’t see an answer, so for those of you that had the AE tool, has anyone tried the Windows version of AlfaOBD with the USB to OBD2 cable that came with the AE tool? Wondering if I can use that to connect instead of getting the bluetooth.
duunoit
EcoDiesel
Any Auto High Beam mirror should be Auto Dim as well. The light sensor for the Auto Dim works in coordination with Auto High Beam. I see the auto dimming mirrors listed incorrectly all the time on eBay saying their Auto High Beam when they are not. This is a picture of a Auto Dim/Auto High Beam mirror for the 13 to 16 Ram with the plastic mirror cover removed. If you are wanting to add Auto High Beams to your truck this is the mirror you need. If it does not have this camera lens type setup on it is not an auto high beam85ee4b72c47905b903eb1fbf795dde56.jpg
I’m pretty sure that camera looking thing is the sensor for the rain sensing wipers. The little white square should be the sensor for the smart/auto high beam. The auto dim sensor is the little circle facing you in the top center on the mirror face.
Ricks Ram
That is incorrect. The small white lense is for the Auto Dim feature only and not the Smart Beam feature. The camera looking lense is actually for the auto high beam and detects light sources from the front of the vehicle and adjust the headlights accordingly. It does work in conjunction with auto dim feature as it adjusts the speed at which your Auto High Beam feature will function by detecting the amount of ambient light present. The small little circle that's actually on the face of the mirror detects headlights behind you and activates your auto dim mirror when the little white square on the front of the mirror detects the ambient light source is low enough for it to function. I only know this because when I did mine I thought exactly what you are thinking until 00/RT sent me a link to the correct mirror and explained the difference to me.
duunoit
EcoDiesel
That is incorrect.
Rick is correct. D@mn junk yards :)
This is what the mirror looks like with BOTH the SmartBeam Sensor (clear window in the mirror cover/cup) and Rain Sensing Wiper feature (the darker black square in the windshield tint).
FXCLM5
2017 Laramie CC
ED 3.0 V6
A word of caution: I wouldn't recommend going in and changing certain engine or transmission parameters with this tool if it is capable unless you are absolutely sure of what you're changing. You can get into some real problems if you change things the wrong way and don't remember what you did or you're unable to put it back.
Yes i agree, all I want to do is try to mimic what other tuners are doing with their tranny tunes through the obd port such as this:
Eliminates 2-1 downshift hesitation at low speed tip-in maneuvers (i.e. rolling stop sign re-acceleration)
• Upshifts earlier in all conditions for improved fuel economy.
• Downshift criteria revamped to best utilize engine torque curve and stay in each gear longer.
• Hill mode optimization to prevent gear hunting
• Refinement on shift scheduling in altitude to provide better engine responsiveness
• Revamped warm-up mode scheduling to provide faster engine warmup (i.e. 1-2 gears lower compared to normal shift maps)
• Increased minimum engine speed after upshift during DPF regeneration for better regen efficiency (this feature will only appear with the GDE Hot Tune installed in ECM).
• Eliminated shift schedule offset based on steering wheel angle to give better continuity of powertrain presence.
• All new tow/haul mode scheduling for maintaining best engine speed range during trailering.
• More use of converter lockup and reduced slip rates to reduce tranny fluid heat load and improve fuel economy.
• More linear response in shifting in medium/high load.
• The shift speeds are quicker and torque response optimized.
• Positive torque requests enabled during downshifts at lower engine speeds for smoother and quicker shifts.
• Torque management maps calibrated for proper clutch control in high output applications (i.e. GDE Turbo Kit, etc), and positive torque enabled during closed throttle downshifts for improved shift comfort
• Highway passing downshifts are sharper and torque is immediate.
• Holds gear better while towing and less hunting on grades.
• Raised absolute input torque limits to enable full torque capacity of GDE Turbo Kit
• Ram vehicles now feature our GearCommand™ feature letting the (+) and (-) buttons on steering wheel to command up- and down-shifts when pressed instead of setting max allowed gear.
• Enables 2nd gear launch from a stop using wheel buttons (Ram) or steering wheel paddles (Jeep).
• Jeep Eco Mode now remembers the last mode selected instead of defaulting always to Eco Mode (for 2014-2015 vehicles)
• Jeep Eco Mode now starts in 2nd gear by default and features a shift scheduled designed for fuel economy.
Imma try and just look through the tranny settings and see what I can learn before messing with it.
The only REAL thing i want are these ones:
I need to find someone with a aftermarket tranny tune, plug in and compare what the differences are in each category with the alfaobd app.
icetraxx
Mine came in yesterday and I'm hoping to get some time to play with it today. I have a performance and trans tune installed in my '17 Sport. I'll post up what I have.
Chach
CA
Cummins 6.7
Has anyone tried to adjust the tire pressure with this app?
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
I'm going to post up a link to the screenshots of my 18 Ram1500 Laramie's BCM settings (5.7L/8spd/3.21 4x2) using the AlfaOBD for anyone that wants to look/compare. Again all this is at your own risk so be careful with what you change.
18Ram1500 Laramie BCM settings link
https://drive.google.com/folderview?id=17bwuc3oCIX8rULPYCwnscjkDVPKbcRcl
PS: if you have a 2018 Ram, you need to bypass the security module using our Bypass harness to be able to connect to the BCM with any scan tool (except the dealer's).
2018 RAM Security Module Bypass.
M² Mods.
1) How do I purchase this harness and how does it install?
2) I have an OBDlink MX WiFi model. Will it work as well? This was the unit I used in my F-150 with Forscan, the Ford version of this tool.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
@deereguy can make you the bypass harness if he still has parts. Send him a pm with your name/email so he can send you details.
My guess is the OBDlink MX wifi will also work... Have you checked to see if it's listed on the Alfaobd site?
M² Mods.
chrisbh17
Fwiw I have a bafx elm327 adapter and it connects with alfaodb with no problem.
Sent from my Nexus 6P using Tapatalk
FXCLM5
2017 Laramie CC
ED 3.0 V6
This made me jump outta the driver seat!
I have a zf8hp70 not the 45, the alfa connected using the zf8hp45 protocol (does not have a 70 - also my truck is a 17 but when connected it says i connect to MY16 body module), but when trying to pull info i got that.
Is that a common warning, or do you guys think i coulda bricked the tranny control module?
I unplugged and started my truck and decided to come inside now lol
Bettula
