AlfaOBD
G-Ride990
Administrator
Administrator
Chandler, AZ
Just wanted to let everyone know by enabling LED turn signals & parking lights I was able to remove the burning hot resistor I had wired in with my switchbacks. So far been about a week without any bulb out light or fast flashing
I still have my resistors in but I get a park light out message when I use my signals. I have tried led settings before with no luck.
You don't have any errors now with the led set and no resistors?
Maybe it's the resistors that are messing my stuff up then.
You have quads with switchbacks correct?
78Staff
US Navy Veteran
NE Florida
The temp sensors on the 13 and up should all work fine. I have a set of 16 mirrors on my 14 with no issues.
Well it say 61* now, so at least it's moving. :rolleyes: I'll keep an eye on it.
HeloPilot19
Justin, TX
6.7L Cummins HO
I also wanted this option. Fortunately for me, this option along with cruise control high idle with my G56 were just added benefits that came with my tuning from HPP... I don't think it's as easy as a setting in the bcm. I think it's in the ecm. *BUT* if the '17 bcm that is shared is also tuned to keep the exhaust brake on, check your "eco mode configuration" setting. Right below the vgt turbo setting. Mine is set to remember last state.
Thanks, I will take a look and see if it will work for me. I am going to get my truck tuned soon, but want the exhaust brake NOW!:(
walker111
So, I'm super late to the game on this and this thread is too long to sift thru. Is the original post updated with everything AlfaOBD can do? Is there an original thread that states what year/models this works on? Explains the installation? Thanks.
prohunter
Largo, FL
Welcome to the party the original thread does state all the current know working codes it covers 2012 to 2018 but with 18s you need a bypass harness
Ghost_RAM
Ghost_RAM
VA
The first post has loads of useful information including links to an offsite Google Drive folder with additional info.
Please, read and take your time. Take copious notes and only make changes you are sure of.
Rez103
Plymouth MA
Yea no errors with switchbacks & no resistors in my quads
Rez103
Plymouth MA
What headlights are you running now?
Sent from my Nexus 6P using Tapatalk
They’re just regular quads. Haven’t tried led for the headlamps yet just the running & signal
Ghost_RAM
Ghost_RAM
VA
@Rez103 Would you mind posting the steps you took so that I can update the known working? Thanks
chrisbh17
OK.. What bulbs did you use to replace the incandescent?
jshillin
This one made them work:
Car configuration change: Mirror Approach Lights Present: ' NO ' -> '1 ' (YES)
Thank you! Just went out and made this change quick and the puddle lights work now.
Mrmagoolin
Pendleton OR.
Cummins 6.7
Can someone add a file to list the out the abbreviations. I am having a hard time figuring some of them out. Is BCM body control module? Is CSM customer service module? Etc. Or is there a list somewhere already?
Sparky853
2017 1500 SXT CC 4x4 6'4" Air Suspension
BCM is correct, CSM is Customer Settings Menu (the menu you see on your radio)
Sent from my VKY-L09 using Tapatalk
Mrmagoolin
Pendleton OR.
Cummins 6.7
Adjusted mine today, changed to the Toyo 35" AT, which is not exactly the same as my tire (Nitto 35" AT), but probably close enough, at least closer than stock tire size :). It's the only Flotation size listed, although I suppose I could try 285/65R20 if it is listed. Anyway, I went from being 3 MPH slow on the speedo at 75 to being dead on to 1 MPH fast at 75 based on the GPS. lower speeds were pretty much dead on. :waytogo:
What steps did you do? I get the ABS and trailer service error. Would you put the steps in google drive?
kad
Hudson Valley, NY
5.7L HEMI
I don't think there is, but I think it's a good idea. I'll start and lets see if we can get a good list together of the common ones seen in and around the app and then ask @Ghost_RAM to add it to the shared drive files.
ECU - Electronic Control Unit (basically, generic term for anything listed here as a "Module")
PCM - Powertrain Control Module (Engine computer)
BCM - Body Control Module (Body computer)
CMS - Customer Settings Menu (the menus on the radio)
DRL - Daytime Running Lights
DDM - Driver Door Module
PDM - Passenger Door Module
ICS - Integrated Center Stack (aka the Radio, HVAC controls, switches, etc)
VTA - Vehicle Theft Alarm
EVIC - Electronic Vehicle Information Center (aka the Instrument Cluster)
IPC - Instrument Panel Cluster (what the EVIC is labeled in AlphaOBD)
RFH - Radio Frequency Hub (handles communication with the Keyfobs and TPMS sensors)
"Key in MAR" - Key in the Run position, but engine off (not running)
CHMSL - Center High Mounted Stop Lamp (aka Third Brake Light)
Additions and correction more than welcome! I'll keep this post updated for as long as the forum software will let me edit it.
-K
Ricks Ram
That's strange. I set mine to the 35x18x12.5 Toyo with the tool and I have no issues. The developer sent me the patch before it was released so not sure if that was the difference. I did mine with one setting. It's on the first page that comes up when you enter the BCM. It's down towards the bottom of the list a few spaces before (car configuration change). I hope the new update that came through to everyone isn't somehow different. I haven't tryed to adjust any tire sizes since I downloaded the full update. This is a picture of the screen that I used to correct my tire size. I have also seen it on another screen it this is the one I used.Screenshot_20181029-075611_AlfaOBD.jpeg
Mrmagoolin
Pendleton OR.
Cummins 6.7
Thank you. I used windows so a little different screens, but the same "program tire size". I switched it back to the original size and the issues went away. Maybe i need to see if there is a update or patch for the windows version? I just downloaded Alfaobd two days ago.
Ricks Ram
The original problem I had was that when I changed the setting it didn't do anything. It would stay wherever the factory setting was. I emailed the developer and he sent me the patch and then it actually changed the setting. From what I have heard the patch was included in the latest update for the the Android version. I'm not sure when the last update was for windows. You seem to have something different going on. Yours seems to make the change but somehow causes issues with the other systems. I am curious to see if others have the same issue. I am also curious whether or not mine will still work correctly but I haven't tryed to change anyones tire size since I did mine before the latest update.
78Staff
US Navy Veteran
NE Florida
I used same process as Ricks Ram - it's a single step under Program Tire size and choosing the appropriate tire. I've heard of others also getting ABS CEL when changing, but I didn't. If you just downloaded you likey have the latest version, but double check and maybe try again.
firefox9
